Need Help Bad.
Old Mar 16, 2008 | 06:31 PM
911twinturbo's Avatar
01 E430 / 07 S550 / 01 996 TT
Exclamation Need Help Bad.
:s lap:ok i just tried to put in 2 12s but didnt work out too well......
now my power windows wont work except the drivers not includin rear passenger windows none of them will work they work but when i click the window button down more to the second click it jsut stops!!!. also my head unit just locked up on me it says CODE with the C blinking!! i need help badd. when i was installing i opened up the panel that had the window buttons on there.. soo.. yeah. thanks yall
Old Mar 16, 2008 | 06:53 PM
ohlord's Avatar
Did
you unhook the battery while working on the system?If so resync the windows.If not check the battery,all fuses you could have shorted out,and reenter the radio code.
2 12's? you could have installed one 10in death box from steve at
http://www.decware.com/newsite/mainmenu.htm and blown your doors off
what are you driving the subs with?
Old Mar 16, 2008 | 08:00 PM
01 E430 i took everything out im not even gonna mess wit it anymore. but yes the battery was restarted and what do you mean by resyncing the windows. but my radio is still locked
Old Mar 17, 2008 | 12:43 AM
johnny's E320's Avatar
1998 E320 Sedan
Originally Posted by 911twinturbo
...what do you mean by resyncing the windows...
To Re-sync the windows:
1. Roll the window down a bit and then roll it back up and continue to hold the rocker switch in the up position for at least 5 seconds, then release it.
2. Done.
3. Do the same for all the other windows and then the sunroof (holding the sunroof to the 'close' position and hold for 5 seconds).
4. Done, again.
Old Mar 17, 2008 | 12:53 AM
1998 E320 Sedan
...but my radio is still locked...
Do you have the owner's manual and the radio operations guide with the code card? If not, then you might have to go down to the local MB dealer and show proof of ownership so they can get your CODE for you.
I would also write it down and keep a copy of it in your home.
Old Mar 18, 2008 | 12:06 AM
eXpLiCitW210's Avatar
I own a 1999 W210 Mercedes.
Wow that sucks, so did you end up checking all your fuses?
