1997 E320 air conditioning
Old May 20, 2008 | 05:53 PM
MB Enthusiast's Avatar
1997 E 320 - 2000 S500
I have a 1997 E320 with dual zone air.
All of a sudden I am getting hot air out of the drivers side and cold out of the passanger
I am in Florida and of course it is not the oposite with cold comming out of the drivers side instead
Help its hot out here!!!
Old May 22, 2008 | 01:08 AM
mwalkerd's Avatar
2000 w210
most issues discussed in forum, i just been thru whole a/c issue, if its low its a leak somewhere, or refer to DIY post on doing a diagnosis using climate controls. -use search and type in a/c. you'll get it all, but like i said, most likely a leak
Old May 23, 2008 | 04:07 PM
Why would I get freezing cold out of one side
I have freezing cold comming out of one side and hot on the other
I would think this is a vent issue or a control issue
Help its 95 degrees
Old May 23, 2008 | 06:12 PM
ohlord's Avatar
Monty
is a student in progress
This is where he was trying to send you.
http://www.eclassbenz.com/node/27
run the tests and errors,punch them into the program.
Either low on 134a which will cause warm on one cool on the other or a stuck duovalve.
give them both a tap with the end of a screw driver handle.
Diy for location of duo valves on benzworld.org w210 section
post the values and error codes here after you have ran the tests.
ohlord
Old May 25, 2008 | 09:14 AM
Thanks Brother
I will try this now
It 90 - 95 here and humid
I need to fix this quick
Thanks for the direct direction
Old May 27, 2008 | 05:34 PM
Checked readings
The readings on my air are as follows
1 - 32
2 - 33
3 - 29
4 - 24
5 - 30
6 - 76
7 - 11
8 - 49
E Code FF Only
