command problem
Old Jun 16, 2008 | 05:09 PM
mbeech's Avatar
E280
command problem
i have tried to use my navigation today but was unable to move the cursor around the map area to select a destination. has anyone had this problem before and found a solution?
thanks
martyn
Old Jun 16, 2008 | 11:16 PM
Ozcan's Avatar
E430 4matic 2001 & ML430 2000 both Silver / Ash
I never experienced this problem. But, try resetting the Comand unit by removing the battery lead for about a minute.
Good luck
Old Jun 16, 2008 | 11:37 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Also try this...remove the Nav CD and see if that will fix it
Old Jun 17, 2008 | 12:14 AM
walker203's Avatar
S55, C230
+1 happened to mine as well for a strange reason but simple cd reboot solved it
