Steering wheel adjustment not working
Old Jun 24, 2008 | 05:44 PM
EdzBenz's Avatar
W210 W140
Hello,
I was working on my car the other day, and needed to adjust my steering wheel position to move around easier in the car. I retracted the steering wheel the farthest it can be toward the dash. I tried to adjust it back to my normal driving position later and the adjustment does not work now. I only hear a clicking noise coming from the steering column when I press the adjustment button.
Does anyone have any ideas on how to fix this or what is wrong? Any help is appreciated. Thank you,
Old Jun 24, 2008 | 05:57 PM
ohlord's Avatar
you
may have gone past the point of the last gear.will it lower?lower it to the lowest position and gently pull towards you while using the adjustment, if the wheel will not move in any position check the fuse.
ohlord
Old Jun 25, 2008 | 04:47 PM
EdzBenz's Avatar
W210 W140
The wheel won't lower or move at all. Does anyone know which fuse it would be? Thanks,
As always, thanks Ohlord!
Old Jun 25, 2008 | 06:18 PM
EdzBenz's Avatar
W210 W140
No need. I found the fuse list on benzworld.
Old Jun 25, 2008 | 09:21 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
If you hear clicking it is most likely not a fuse. There is a plastic coupling in the mechinism internally and that may have failed and may need to be replaced.
Old Jun 26, 2008 | 03:47 PM
EdzBenz's Avatar
W210 W140
I haven't checked the fuse yet, and I am hearing a clicking noise. What is the procedure for checking the plastic coupling?
Old Jun 26, 2008 | 03:55 PM
sosh's Avatar
Believe you must disassemble the mechanism. On the W210 that I had with this failure I could hear the motor running very faintly when the lever was held in one of the positions. Had the dealer fix it, do not remember the cost but it was insignficant.
Old Jun 28, 2008 | 03:53 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
It looks like the adjustment motor is on the column underneath, and you may be able to access it just by removing the lower dash panel.
