Any bluetooth phone kit for W210?
I did not buy the phone option back then because they wanted too much for the packakge. I would like to take advantage of the radio and speakers that is already wired in the car.
Incartronics website that carries the Argos unit...and then it listed an authorized dealer in Moorpark (Southern California) called Autotech Security.
I called them (Autotech) and he explained that it would cost $1099 installed because he would have to rerun/redo some fiber optics lines and install/modify fuses as needed...claiming it would take him from 1-3 hours to do..depending on how many fuses he has to do. So I don't know if he is trying to make a killing on these installs or what???? He claims he does work for 12 different MB dealers....
I was surprised to hear that it only took you 5 minutes to plug and play.
Again, mine is a 1999 E320....should be the same process as yours?
depending on if you have cd changer or not you will have to make a fiber optic loop....THe way this is accomplished is by purchasing the additional fiber optic cable and basically removing the two connectors behind the trunk liner and connecting this inline to the connector. You then will connect the centronics cable to the argos unit and you are basically done. It took me about 5 minutes to do it after reading the instructions. The person quoting you 1-3 hours to do this is charging an excessive rate. If you get the argos unit I can help you, the price he is charging is probably more inline with the factory mb bluetooth puck. This actually requires some version coding , and running of wires etc to get it to work properly.
If you do not have a cd changer it will take even less time you basically plug in the cd changer connector (already located under the trunk liner) and the centronics cable, use the included zip ties to attach the unit and you are done. Its amazingly simple and it would be silly not to do it yourself.
Half of me is saying spend the money and take advantage of the already built in phone system (head unit and speakers)....the other half is questioning how often am I going to utilize the system.
But it is definitely good to know that it can be done ...thanks to members on this forum.
W210.
If you look towards the side mirrors you will see 2 triangular shaped speakers...those are the audio source.
