Coolant full flush procedure
Thanks in advance
-Look underneath of the car on the front, driver's side of the radiator. There should be a little red knob. This is the draining plug.
-Above the draining plug, there should be a "nipple" that faces towards the passenger cabin. This is where the fluid is going to come out once you turn the red knob.
-Find a rubber hose that secures to the "nipple", and then into a bucket/jug
-Take off your reservoir cap
-Turn the red knob, and the radiator will drain. Caution- Do not turn the red plug too much or it will come out and fluid will also drain out of there too.
2. I know Coolant doesn't come out from the engine block without starting the car. So how do i drain the coolant from the engine block and where is it located?
3. Can I drain the radiator and then starting filling the water in the bottle with the hose and start the engine it will remove the coolant from the engine block. Then stop filling the water and start filling the new coolant while engine running and when I start seeing the new coolant coming out from the radiator then close the radiator cap and keep filling the new coolant while engine is running. Is there any thing wrong with this procedure??
4. After draining the coolant, do i need to fill up the water and drive couple of days before filling the new coolant or it is no necessary?
You will get air settling out after the refill, but it shouldn't be a problem.
Make sure to use MB orange coolant or you will get accelerated corrosion.
ohlord
it lubricates the water pump and increases contact of the coolant in the water passages making the cooling system more efficient.
sold at any good parts store
http://www.redlineoil.com/products_coolant.asp
really works
ohlord
