Wiper blade wont work, 97 e320.
After I was done wiring a new piggyback ecu to my car the wiper blade started not working. The only thing I can think of is that the wiper is connected to the cam sensor for varible wiper speed but im not sure if this car even has that. Everything else on the stick works like the signals, washer fluid, and high beams so im stumped.
Put power to them,if they work
break them off the circuit with a relay and a separate switch.
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Boost first,wipers are secondary
Went to check it out to make that bypass and noticed there was a plug half plugged in on the main ecu that i took out in the process of wiring in the new ecu. It was a slide lock and the slide was down but not locked in so it wouldnt plug in. It took me like 10 minutes but i figured it out and got it plugged in and the wiper works now lol.
Just another case of me not checking everything out.....again.
