problem after rims
Old Sep 13, 2008 | 02:49 PM
dylokjai's Avatar
00_e430_sport
problem after rims
the place where i took the rim to be mounted on put on a longer stud lug and made a clunk noise..so when i finally figured it out and replace a shorter stud lug my car is making a hissing squeeking sound whiile going 5mph when i go fast teh sound goes away. this is only on the left rear passenger side.. what can it be? and what is inside the hub inside where the long stud went in...
Old Sep 13, 2008 | 03:26 PM
ohlord's Avatar
It
went through and hit the brake system,check the parking brake ,check for damage to the backside of the rim,check the whole system.Now
ohlord
the shop is obligated to fix the issue.
Old Sep 13, 2008 | 07:58 PM
dylokjai's Avatar
00_e430_sport
before i go out to a indie shop or the dealer...
what the price range for parking brake assembly job on one side only?
Or is there a DIY?
Old Sep 13, 2008 | 10:20 PM
ohlord's Avatar
Go to
the shop that installed the rims and have them inspect the damage.
Old Sep 13, 2008 | 10:51 PM
dylokjai's Avatar
00_e430_sport
i wish i can but its 148miles away.. i think the more i drive it the more damage it might get..and dont want to pay for towing since i dont have AAA. lol
Old Sep 13, 2008 | 11:36 PM
SLOPESTAR's Avatar
99' E320 4MATIC ESTATE / 92' 190E 2.6
maybe stock is the best way to go. ix nay the ally ray. or the owerred lay. get it!?
Old Sep 17, 2008 | 06:31 PM
dylokjai's Avatar
00_e430_sport
Does anyone have the picture with part numbers for the rear parking brake assembly?
Old Sep 17, 2008 | 06:32 PM
dylokjai's Avatar
00_e430_sport
Huh?
Old Sep 17, 2008 | 09:48 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Most of the Time when a Tire shop installs a longer wheel bolt..The Bolt knocks off the Parking brake shoe hold down spring as it sticks out and its the first to go
remove the rear brake caliper
remove the rear brake rotor
inspect for damage
Old Sep 18, 2008 | 12:10 AM
dylokjai's Avatar
00_e430_sport
Is this what i need since it comes with springs and stuff in the set?
http://www.autohausaz.com/search/pro...e%20Shoe%20Set
Old Sep 18, 2008 | 01:16 AM
Thats the set..make sure its for the correct car s the pic is for a W124
The Springs that fail are in the pic..right side four of them
Old Sep 18, 2008 | 03:28 AM
dylokjai's Avatar
00_e430_sport
thanks mark? Are you really located in HB? if i cant figure it out can you help me since im in HB area?
Old Sep 18, 2008 | 11:04 AM
Np
Yes Im in HB
Take a look at it then let me know
Old Sep 18, 2008 | 10:10 PM
Red66GT's Avatar
2008 S63 AMG Designo Edition
Originally Posted by dylokjai
Huh?
It's ig pay atin lay (pig latin).
Old Sep 21, 2008 | 08:18 PM
dylokjai's Avatar
00_e430_sport
i couldnt take the rotors off so i took it to some indie place it took them 1.5 hours trying to remove the rotor to take a look and 10minutes to replace the hold down spring and only charge me 75dollars....problem solved
Old Sep 22, 2008 | 01:27 AM
ohlord's Avatar
Send the
bill to the tire shop that botched the job.
Old Sep 22, 2008 | 11:18 AM
dylokjai's Avatar
00_e430_sport
thats what i was going to do. i even took pics to prove to them that they used the wrong size lug bolt and screwed up my ebrakes.
