BAS/ASR ABS warning
'01 W210 E320 CDI
BAS/ASR ABS warning
I can't pinpoint a certain condition when it happens. It seems to happen more under wet conditions, but then again it also happens in dry weather. Sometimes the warning goes away when I turn off the engine and restart again, sometimes it stays on the whole trip. I've done some reading up on these fourms about it, however when the warnings lights are on the cruise-control still works!? Is this an indication of something in particular?
93 320CE, 72 280SE 3.5, 55 220A, 05 E280CDI, 88 Mini Mayfair, 90 Peugeot 205GTI, 04 Mini Cooper
Check your fuses. My car does this occasionally and all I have to do is "wiggle" the fuse and the warning lights go off (the fuse is not blown).
Brake switch
get the upgraded one at the dealer,diy on benzworld.org w210 diy section.Problem solved.
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
'01 W210 E320 CDI
Originally Posted by TMAllison
Should be one of three issues: Speed sensor, brake switch or batt voltage. I'd rule out the latter two first.
2000 E320, 2007 Land Rover LR3 HSE, 2008 E350
You have a 'brake light switch' that will soon need to be replaced (very common) - you will periodically get the warning signals; the brake light switch is going bad! It is a really easy DIY for under $20 at your local MB dealership! Good luck!
