Oil suction method is great!
Another convert
no lifting,no worry about getting the plug into the best drain position,no removing plastic shield.
Priceless.
0w40 mobil1 and fleece filter and you are done in 1/4 the time
I admit I was skeptical at first...not no more...saw it with my own eyes that it removes more oil from the pan.
I used to drive my car onto a home built ramp that would raise the front left tire (driver side) up 3-4 inches to tilt the pan towards the drain plug and still that did not drain as much as the suction method.
This model has a switch/valve so that you can pump the collected oil to another container if you wish to use it....kinda nice feature.
We have a boat with a Diesel engine that has a separate oil evacuation tube as part of the engine design. You simply tap into the evacuation tube fitting that is plumbed directly down to the lowest point of the sump and there is no need to snake down the oil fill. Wouldn't it be nice if the auto transmission had a similar fitting?
We do have up to 8 quarts of old oil in our model.
quart/liter...is almost the same.
Product Features
Features a large 8.8 liter (2.3 gallon) capacity bi-functional manual unit to extract and dispense a wide-range of fluid types
Clean and simple way to evacuate and dispense fluids
Reservoir is constructed of durable polyethylene and will not rust or corrode
Automatic flow control valve prevents the unit from overfilling during use and automatically shuts off at 8 liters
Kit comes with 5 feet of flexible hose and two rigid dipstick tubes for engine oil removal
From my experience... I am able to get about 7 to 7.5 quarts of fresh oil in after an oil change.
will make you wish you had stuck with that most ancient and stable of all sources, gravity.
My car computer displayed ADD 1 qt. last night....which makes up a total of 8
new quarts. of new oil added...previously I was only adding 7 qts. after the convention method.
If that is the case...then they have forgotten to tell us how to properly seat the filter element in the first place...I think most people would stop twisting the filter on once they reach the initial resistance.
I sold the miata, it was just too damm small, I never felt safe in it...
The only downside, I only get 7.0 quarts out using this method...
