Reverse is very shaky
Old Sep 21, 2008 | 11:15 PM
MB>BMW's Avatar
G63 W463
Hey guys,
So I have been loving my w210 but recently a concern has come up.
When i shift into reverse, the car is a very noticeable vibration, the gas is lagging(meaning i have to put my foot down alot to make the car move), it feels like its almost hesitating.
My car is about to reach 118,000.
I have NOT performed the transmission fluid change as mentioned many times on here, but i am considering it soon.
Any suggestions?
Thanks in advance
Old Sep 21, 2008 | 11:32 PM
whoover's Avatar
'19 E63S sedan
It might be transmission, of course, but also check your flex discs.
Old Sep 22, 2008 | 01:24 AM
ohlord's Avatar
It is
well past time,don't consider it.Do It.
inspect motor mounts at the same time.
MB service on the newer w211 same trans 722.6 is filter and fluid at 39000 miles,I think you are a tad past that.
Old Sep 22, 2008 | 12:36 PM
MB>BMW's Avatar
G63 W463
do
Im sorry, im a bit oblivious when it comes to transmissions.
would changing the fluid make the difference since its only causing the vibrations in reverse?
i used to have the shake in drive but i replaced the coil packs and ball bearings, etc that fixed that problem
thanks in advance.
Old Sep 22, 2008 | 03:09 PM
Britrover's Avatar
01 W210 E Klasse | 02 W 463 G-Wagen | 06 Land Rover LR3 HSE
I think you have two issues :
1 - Check your motor mounts. I am 99% sure they need to be changed.
2- Some issue with your transmission. I have a very similar issue to yours and am having it checked up tomorrow.
Cheers
Old Sep 24, 2008 | 12:53 PM
EdzBenz's Avatar
W210 W140
Also check your transmission mounts
Old Sep 25, 2008 | 12:24 PM
MB>BMW's Avatar
G63 W463
problem is intermittent, goes away when warmed up, but reaction is still very slow
