Sway Bar parts.
Sway Bar parts.
Hey there. I need to change my sway bar bushings, and sway bar bar links. Where online can i get these parts from?
Also i just installed H&R springs and bilstein sport shocks. Is it worth the money to upgrade AMG Sway bar? If so where can i buy one. Thank you.
try
autohausaz.com,I know they have the down links.They probably will source the bushings if you ask them.Lowered springs and sport shocks,unless you are going to the track or like to feel like you are on rails no need for the amg sway.Spend the money on the camber eccentrics for the front end and the link kit for the rear end,so you can get it properly aligned after you replace the worn suspension parts,and since you have dropped it into the weeds![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
properly: is load and height rated on the hunter machine
Yup i am waiting on the link kit for the rear, and i was told the dealer can take care of the front end.
I was thinking about getting the alignment done at the dealer? Is this a good idea or should i find someone else with a hunter machine. The price quote for the dealer was around $200 for an alignment a lot of money. I want the job done right.
Also if i can find one for $60 bucks for the sway bar its worth it. Can you tell me where i can get one if that cheap?
Whoops, I screwed up. The w210 E55 rear sway bar is about $250. The front is about $150. Must be the AMG premium.
I looked on autohauzaz and mercedesshop to double check it, but neither carries it.
Part number for the rear is 2103260165
