brake squeak
Old Jan 6, 2003 | 11:46 AM
2quik's Avatar
brake squeak
Brakes squeek at stoppping at low speeds, like from 2mph to zero, and as u release the pedal slowly , they make a annoying noise, should i bring it to dealer? its a 2000 e430 , its under warranty still
Old Jan 6, 2003 | 01:50 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
On a 2000 model year..The car has 12mo 12,000 mile Adjustment period.From date of sale..The dealer Will take care of adjustments..Including Brake Squeak..After the period the dreaded brake squeak is a Customer Pay item
You can remove the pads, file the edge of the Pads at a 45 and Install antisqueak on the BACK Side (The Metal Backing of the brake pad)
It Should Stop the pads from making noise!
Old Jan 6, 2003 | 04:41 PM
MBDriver's Avatar
2001 E 320
Re: brake squeak
Well why not??? If you got a warranty then use it. Brake squek is very annoying, I would be bustin the dealer's door down if I was you.
Old Jan 8, 2003 | 11:08 AM
2quik's Avatar
MB
Ok guys , i complained about my break noise at the dlr, he said nothing he can do , its not under warranty, states wear and trar isnt covered in the warranty, any ideas guys? is this true or is he busting on me
Old Jan 8, 2003 | 12:53 PM
Please go back to dealer if your car has LESS than 12,000 miles or LESS than 1 year old from date of sale (NEW)
That period is ADJUSTMENT and Mercedes WILL cover brake pad squeak...I Was a MB Tech.. If they are B/S ing You try a Good dealer..BTW did You buy your car at this dealer?...they use that sometimes or the Service advisor is Just not Customer friendly
Or talk to the Service MANAGER
If you Did Buy the car at that dealer.(New) With less than 12/12.You Will get a 12mo survey.From Mercedes Benz.and YOU can Use that survey to SLAM the Service Advisor Its called Leverage or talk to your sales person..Cause Mercedes Will send a copy of the survey to the dealer with stated remarks from you...And Mercedes Does use this for Guide to rate the Dealer on CSI Score...
Good luck
