coil replacement question
Old Nov 24, 2008 | 01:27 AM
d2Benz's Avatar
2017 GLE350 4MATIC, 2009 ML350 4matic, 2005 4maticWAGON (sold), A Pre-facelift W210(sold)
I've got a Misfire in cylinder 1..
I changed wires and plugs..still misfire...
Coil is next culprit.
QUESTION.. If one coil goes bad, is it necessary to change ALL 3 coils?
car is a 96 e320 with 187,300miles.
I figure, if one goes bad, the remaing 2's life might be limited...
*I've heard many change coils, but no one really specified if they change all..
thanks
cheers,
Old Nov 24, 2008 | 02:24 AM
ohlord's Avatar
did you
change the plug connectors?Do that first and if no improvement swap a coil and see if the misfire moves with the coil.
This is the part that usually is the weak link in the M104 ignition system.
http://www.autohausaz.com/search/pro...ug%20Connector
did you use the proper copper plugs and not get fancy and install platinums.M104 hate plats.
Old Nov 24, 2008 | 12:58 PM
d2Benz's Avatar
changed....
Plug connectors are changed.
question is... Is it necessary to replace all 3 coils OR just replace the failed one.
since all are the same age....
thanks for your response OhLord!
Old Nov 24, 2008 | 02:49 PM
ohlord's Avatar
Did you
swap a coil to confirm that it is not a clogged injector?
If the coil is bad just replace that one.$60 at autohausaz.com
Or find one at an mb wrecker.
Old Nov 24, 2008 | 09:20 PM
d2Benz's Avatar
Yes
coil was swapped and cylinder 1 is still misfiring...
where do I go from here???
Old Nov 24, 2008 | 09:28 PM
ohlord's Avatar
check the connector ,check for moisture,
check the injector operation with a stethoscope,should sound like the others.So coil is not bad,fuel or spark to that one cylinder is only getting affected.
Seafoam injector in half a tank of gas will clean the injector.
Old Nov 24, 2008 | 09:45 PM
d2Benz's Avatar
OhLord!
could this be a bad piston???
Just curious???
thanks
Old Nov 24, 2008 | 10:37 PM
ohlord's Avatar
Probably not
these engines are pretty strong.Most likely the connector and since changed the other issues common to the M104.Swap a connector,then swap an injector.it is probably a very simple issue,don't panic.
Old Nov 24, 2008 | 11:35 PM
koskesh's Avatar
1997 E320
Answer to your question: no, it is not necessary to change all coils. it is your preference. I personally wouldn't change something that's working until it breaks unless it is a safety part.
What spark plugs did you use? on that engine you have to use copper bosch ones. Part number is somewhere on this forum.
Did you clear codes after you moved the coil then start engine and wait for new codes?
Did you change entire spark plug wires or just the connectors? if the wires are old they could leak electricity.
Old Nov 25, 2008 | 12:59 AM
d2Benz's Avatar
thanks 4 response
OhLord,
I will check the injectors and clean them as suggested. I will do the other troubleshootings too. THANKS.. I will not panic. :-)
Koskesh,
wires, conncectors and plugs were all changed.
I used the BOSCH F8DC4...nope I didn't get fancy with the plugs.
codes were cleared be4 reading again.
thanks 4 the advise not to change all 3 coils
I will do as suggested and report back. thanks for sharing your knowledge with me on this issue.
Old Nov 25, 2008 | 08:08 PM
d2Benz's Avatar
yipeeee
Guys thanks for all your inputs and suggestions.
My mechanic & I decided to do everything all over......
plugs/wires/connectors/coil....I only changed the bad coil...
...and all of a sudden FULL POWER...
car seems to have a little more power...
I will do the injector cleaner as suggested by the President OhLord!
the only thing left now is to find a way to clean the clogged egr pipe/tube.
Once again THANKS...
