Automatic transmission not shifting up
This winter, it won't shift at all even after 20~30 minutes of warming up. What is wrong with my transmission? Is this an infamous trouble among Mercedez?
Please complete your profile with Model Year and your location when you have a chance.
I would suggest you get your transmission diagnosed by a good independent MB mechanic or at the dealer. Everyone hopes slippage is due to low fluid level but most often it's something worse. Best of luck.
Have the codes scanned using SDS by a competent tech who can understand the trans adaptation values. That will tell them what is wrong more than likely. Dont "wipe" the ecu memory (promoted here too often) until thats done.
Check the electrical connector for the common leak.
There are times when the dealer and their ability to scan every module and see live/stored data is your best bet. Trans fall into that category IMO, at least from a diagnosis standpoint. Lacking codes, competent review of how the trans has been adjusting itself internally will usually lead the tech to the problem.
Do you have the factory tool to check fluid level? W/O it you can't possibly know the level is correct.
Be gentle with it, when they "go" they seem to go in a hurry.
What mileage does it have? Your indie used the proprietary MB fluid to refill it last year, right?
