Still have breakswitch problem
Old Nov 24, 2008 | 03:20 PM
deno's Avatar
02 E430 4matic 07 E550 4matic
The switch itself seems to be good it shows continuity, battery is reading a little over 12volts, problem still seems to happen when pressing the brake.
I've takin it out aleast a dozen time's and nothing.I will read the codes tommorow and keep you all posted.
Old Nov 24, 2008 | 04:31 PM
ohlord's Avatar
12 volts is to low
what is the alternator putting out?
Did you replace the brake switch with a new upgraded one?To test it you need to test the abs terminals of the switch if it is giving you the dash warnings.Also have you checked for corrosion at the brake light sockets?
Old Nov 24, 2008 | 06:00 PM
deno's Avatar
I checked the light sockets there good, what should the battery volt be reading.
Old Nov 24, 2008 | 06:08 PM
deno's Avatar
The switch is oem and new, I will check alternator in the morning, also when I pull the switch off the socket when the car is running the warning lights come on, thats why it seems to be the switch or some other problem.
