When/where was a manual tranny offerred with e320?
Old Dec 18, 2008 | 07:46 AM
stickygreen's Avatar
'97 E320
I believe I asked this question a couple years ago and didn't get much of an answer..so figured I'd try again.
Anybody know what year(s) and in which LHD market(s) was the early w210 e320 (inline-6) available with a manual transmission?
Old Dec 18, 2008 | 04:18 PM
Semikolon's Avatar
2001 E220T CDI Avantgarde, 2002 E55T AMG
I think all w210s were available with manual transmission, maybe except the ones with the larger engines, like 500 and AMG.
But as automatic trans is standard equipment on a Mercedes it had to be ordered explicitly, and therefore a Mercedes with manual transmission is very hard to find. At least in the European market W210 was available with manual trans.
Maybe not the answer you were looking for, but I can have a look in EPC tomorrow and see if I can find some useful information...
Old Dec 18, 2008 | 10:52 PM
ohlord's Avatar
Euro
market only.
Old Dec 20, 2008 | 04:10 AM
'97 E320
So I guess I can assume a Germans-spec e320 could have been had with a manual trans. Thanks.
Old Dec 20, 2008 | 06:33 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Yes, and if you ride in enough taxis there you may come across one - usually diesel.
Old Dec 20, 2008 | 09:38 AM
lkchris's Avatar
'10 CL550, '12 GL550
Then it isn't an E320, is it?
I've a facelift W210 brochure in German and a manual transmission is NOT available with the 320 diesel or the 320 gas engine or any engine larger. Manual transmissions are only for econobox Mercedes, i.e. the four cylinder models. It ought to be obvious that if manual transmissions are not available for AMGs they're considered lower class items in Mercedes-speak.
Old Dec 20, 2008 | 04:25 PM
Semikolon's Avatar
As a matter of fact, I just did a lookup in EPC, and there is no such thing as manual transmission in the parts database for E320...
The E280, E290DT and E270CDI are the largest engines available with manual transmission
Old Dec 21, 2008 | 02:45 AM
'97 E320
All right...now we're getting somewhere. Does the E280 share the same basic block as the e320?
Old Dec 21, 2008 | 04:42 AM
ohlord's Avatar
That
depends on if the 2.8 is the 24 valve l6 or the 2.8 liter 18 valve v6
Old Dec 21, 2008 | 05:39 AM
Untertürkheim's Avatar
If it's the facelift brochure, they were using the M112/113 engines.
Also, the rest of what you are saying is completely wrong, Mercedes has sold 8-cylinder models, including S and SL models with manual transmissions. Even the W126 and R129 had manual options with 6 cylinder engines. The M104 was paired with a 5-speed manual, but not in a W210, although the E280 was sold with a manual.
The reason MB does not sell a manual in an AMG is that they do not have one to handle the power, it has nothing to do with "prestige". In fact driving an auto would speak more against someone than a real transmission.
Old Dec 21, 2008 | 05:53 AM
'97 E320
So is the e280 based off the m104 block (shared bellhousing pattern), or is it a different casting altogether? Also, which models was the m104 offered in with a manual trans?
Old Dec 21, 2008 | 10:44 AM
lkchris's Avatar
Meaning they've only designed one for the econobox models with smaller engines, right?
Manual transmissions are for "boy racers" and not for folks buying expensive cars. BMW being the exception, of course, but even then their manual trans sales in larger cars are miniscule.
Old Dec 21, 2008 | 11:33 AM
Figuero's Avatar
2002 E430 4MATIC
BUT - Wouldn't a dual clutch AMG with paddle shift be a sweet ride? Hardly a cheap boy racer.
Old Dec 21, 2008 | 12:37 PM
Semikolon's Avatar
Dot get your point
It's still not a manual transmission.....
back to topic..
The E320 (210.055) uses M104.995
The engine code in the E280 (210.053) is M104.945
So it should be the same engine
The manual transmission for the E280 is 717.441
I can dig a bit deeper in EPC tomorrow to see which models that use the 104 block. Right now I can only use EPC on a slow remote desktop connection...
Old Dec 21, 2008 | 05:02 PM
husk323's Avatar
Tesla Roadster Sport
You could get an E320 CDI with a 6 Speed Manual Transmission. I have seen such a vehicle.
Old Dec 22, 2008 | 08:31 AM
'97 E320
Thanks for the part #s. Time for me to do some research...
Old Dec 22, 2008 | 05:22 PM
Semikolon's Avatar
I don't remember if I checked for a parts catalogue on manual trans for E320CDI 210.226, but I don't really think it's there.
Anyways, that is a completely different engine and the gearbox from OM613.961 can not be used on a M104.995. It may bolt on with modifications, but the gear ratios would be wrong.
Old Dec 25, 2008 | 05:31 AM
'97 E320
Hey Semi:
Where are you finding these part #'s? I'd like to try put together a list of necessary parts for a 5spd swap (tranny, flywheel, clutch hydraulics, pedal box, etc...)
Old Dec 26, 2008 | 01:47 PM
Semikolon's Avatar
I used Mercedes EPC (Electronic Parts Catalogue) for the info I provided earlier..
