E320 wagon. Won't Start
Old Dec 23, 2008 | 10:18 PM
digicanuck's Avatar
2000 E320W 4matic
I went out this afternoon to get a christmas tree. Once the tree was loaded in the back of the wagon. I got back in to start the car. Nothing. All the lights worked but no cranking. No sound.
I tried it again. Then everything off. door locked then unlocked. Nothing.
I call my mechanic. He said to try it in neutral and park. Nothing.
Lights are bright. The car seems good. It is minus 10 C.
I get a boost from truck. Nothing. Towed to garage. We try all tricks. Nothing.
Any ideas. The car is 4matic. The starter is deep job. Labour will be high!
Old Dec 24, 2008 | 04:45 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Nothing happens when the key is in the crank position? Click?
Try to wiggle the shifter in N or P when cranking
or
Try another key
Old Dec 24, 2008 | 05:01 PM
ohlord's Avatar
Battery
can be tricky.Lights can be bright and battery can be well below cranking range.Get it on a 10 amp charger overnight using the under hood charging post,and see what you get.
Old Dec 28, 2008 | 07:07 PM
digicanuck's Avatar
2000 E320W 4matic
I have tried recharging battery. The code we are getting is N15/5. does anyone know what this is?
Old Dec 28, 2008 | 07:24 PM
purplegrog's Avatar
2012 C250
doing a google search on the code you got led me to this page:
http://www.hotequip.com/UploadFiles/...0225322353.pdf
which contained this message:
2030 No or incorrect CAN message from control unit N15/5 (electronic selector lever module control module) (P0600).
I don't know if it does, but I hope that helps.
