Heat on one side and not the other on 96 E320
Old Jan 3, 2009 | 10:38 AM
harv's Avatar
e320
I have just replaced the blower regulator after my wife kept getting in my ear that she was cold.She pointed out that even though the fan is working correctly there still is little or no heat on the passager side. Being the driver who has heat I normally wouldn't care but how much *****ing can one man take? Can anyone point me in the right place to start.
Old Jan 3, 2009 | 04:11 PM
ohlord's Avatar
run the
onboard climate control diagnostics.Post the values and errors.
Seems you have a stuck duo valve that is not letting heated coolant through the wife's side of the car.
You would feel the same way if you were on the cold side,so i will leave it to you to search for the diagnostic program and how to test and repair the duo valve.
Old Jan 4, 2009 | 03:13 PM
harv's Avatar
e320
duo valve rebuild
Has anyone rebuilt a duo valve, BMW had a rebuild kit?
Old Jan 16, 2009 | 12:26 PM
skyrocket2's Avatar
Mercdes 1996 E320
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CFred%5CLOCALS%7E1%5CTemp%5Cmsoht ml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshowes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026"/> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]--> When did fly by wire come in, as I too have a 1996 E-320 auto which is slow on the throttle when its warmed up but has poor gear change when cold, I can live with the poor gear change but having to push the throttle hard down to make go and it’s a pain, I also have a Toyota corolla and you only have to look at that throttle and its gone which can be a bit hairy when you change from one car to the other. <o:p></o:p>
<o:p></o:p>
6 Father's Day Gift Ideas Your AMG Loving Dad Will Cherish
Slideshow: Six Father's Day gift ideas your AMG loving dad will cherish.
By | 2026-06-03 16:34:48
