HELP IGNITION PROBLEMS
Old Jan 27, 2009 | 06:11 PM
ronnie8350's Avatar
200 e320
AS I PUT MY SMART KEY IN THE IGNITION THE CAR WILL NOT ENGAGE. IT JUST BEEPS AND FLASHES REMOVE KEY. THE DOOR LOCK, TRUNCK AND ALARM SWITCH ALL WORK! WHAT DO I NEED TO DO?
Old Jan 28, 2009 | 06:25 PM
Z06EATER's Avatar
1997 C36AMG
umm wel it will always say that the first turn, you turning it all the way? reset the computer
Old Jan 29, 2009 | 11:13 PM
ohlord's Avatar
Test
your battery.Starter load on these high compression engines demands full voltage.Test it.
Old Feb 2, 2009 | 04:20 PM
Z06EATER's Avatar
1997 C36AMG
i see you love them wagons ohlord ahah you bought another eh? looks great!
Old Feb 2, 2009 | 06:34 PM
ohlord's Avatar
The Black one
was bought so it could be the recipient of the E55 engine and the built trans.
It became so nice in the process that I sold it to a fellow member in the Midwest and after spending a few more weeks of going over every nut bolt and square inch of body surface it will be delivered by me on the next road trip.Another Wagon is almost done with the V8.Test drove it the other day stock gearing 2nd gear 6000 rpm 0-60 mph in 4.9 flat.It really feels like it needs a few shift points modified to allow the tiptronic 6700rpm before banging 2nd and 3rd.
OP still needs to load test and specific gravity test his Battery.
Old Feb 2, 2009 | 09:15 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Gotta love a hot rodded wagon. Going full boat AMG or just engine? Would love to see picks. How much needs to be changed for the motor swap from V6 to V8? Any details?
Old Feb 3, 2009 | 05:48 AM
ohlord's Avatar
Engine and trans
not an AMG clone.A sleeper.
built Engine,built trans torque converter,harness,ecu,das,ignition,mounts,and until a rear end can be built to handle the modded engines power,stock geared R.E.
Old Feb 5, 2009 | 06:31 PM
Z06EATER's Avatar
1997 C36AMG
now that sounds hella sick!
