Popping noise
I know i need an alignment badly, my camber is off. I'm not sure if that has an affect on it like that. There was also one time where i had to slam the brakes pretty hard, on the highway, but not to the point of skid marks. Im not sure what the reason of this is, or what is caused it or is causing it. Any help is appreciated.
Another example is if i turn the wheel a bit and jack the car up on the side where it makes the noise the spring will make a popping noise, not all the time just sometimes.
Thanks!
If none of those issues inspect drop link bushings.
If you can create the noise while static ,have someone do that while you safely (proper chocked tires etc.) listen with a mechanics stethoscope.You will know when you get close the pop will be real loud
Also these shocks and springs were installed back when i had the 18's on the car now i put on the 16's just for the winter. I still need to do an alignment i figured id let the shocks accumulate miles break them in and then id do an alignment once i put back the 18's
