headlight conversion
Old Feb 12, 2009 | 12:46 AM
kyosho26's Avatar
96 E-class W210
If i wanted to install a pair of factory HID headlights into a car that didnt have HID. Is it straight forward plug n play? Or is there a lot of work involved. THanks.
Old Feb 12, 2009 | 01:01 AM
Semikolon's Avatar
2001 E220T CDI Avantgarde, 2002 E55T AMG
plug and play..
Be sure to aim them correctly though
Old Feb 12, 2009 | 04:05 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
plus & play plus version coding...
Old Feb 12, 2009 | 05:31 PM
Semikolon's Avatar
Usually no coding is needed. When using OEM ballasts there will be no problem with bulb warning.
Old Feb 12, 2009 | 05:40 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
not 100% sure on W210, but on W203 and W211, u do need version coding even with OEM ballasts
Old Feb 12, 2009 | 05:46 PM
Semikolon's Avatar
They have much more advanced electronics. On 210 you shouldn't need any coding.
Old Feb 12, 2009 | 09:57 PM
kyosho26's Avatar
96 E-class W210
Thanks everyone.
Old May 11, 2009 | 01:44 PM
kyosho26's Avatar
96 E-class W210
Ok, i didnt want to start a new thread.
I got some oem xenon off of ebay and one of them is not working. Its not the bulb, because i swapped the bulb with the working headlight. I'm thinking it has to be the ballast. Anyway to trouble shoot it? Can i just get the ballast from the dealer or do i have to get a whole headlight assembly. Thanks.
Old May 11, 2009 | 02:17 PM
raymond g-'s Avatar
99 E320
do similar, ie swap suspect ballast to other side. if it works, then it's another
problem you'll need to isolate. do *not* buy from dealer or be ready for a
price quote guaranteed to make chuck norris cry like a little gurl. heck, I've
purchased OEM take off ballasts off Ebay from sellers with good feedback and
have not had any problems over the past 4 yrs. heading over to HIDPLANET.
COM is another thought (or others). up to you though.
Old May 12, 2009 | 01:29 AM
suicidal4life's Avatar
2001 E430
I know this is an old thread that got dug up but I just wanted to add to the OP that when I swapped my 2001 E430 lights for a set of E55 HID's it was 100% plug and play.
Old May 12, 2009 | 04:37 PM
kyosho26's Avatar
96 E-class W210
Thanks alot. I will try swapping that and the bulb plug also. THe ballast looks a little tougher to takeoff.
Old May 12, 2009 | 06:00 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
The ballasts are real easy to remove. Just unscrew the metal covers under the headlamps and unplug.
Don't forget the change in bumper covers for the headlight washer systems (left and right) along with the extra reservoir that attaches to the washer bottle. Xenons in the USA are required by federal DOT law to have the headlight washer systems I would assume to avoid any scattered glare from dirty headlamp housing lenses. These lights are 3X brighter than standard halogen bulbs.
