Transmision Problem?
Old Mar 28, 2009 | 01:28 PM
MB Enthusiast's Avatar
1997 E 320 - 2000 S500
E320 1997 250 k
Getting a wineing sound intransmission and not shifting properly
What could be the possible problems
Old Mar 28, 2009 | 03:13 PM
TMAllison's Avatar
09' E320
Has it ever been serviced?
Checked fluid level recently with the factory tool?
Old Apr 2, 2009 | 01:12 PM
ItalianGuy714's Avatar
Stock for now E420
I have a 97 E420 and its at 181k now and I had to get the transmission replaced at 155k.
Old Apr 4, 2009 | 06:08 PM
Transmission has been serviced but
Transmission has been serviced but it has been 50k
Would that cause a winning sound and it apears to be stuck in 3rd or maybe second gear but I think third
Should I get engine light on this type of problem?
Old Apr 4, 2009 | 06:12 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
As stated in post # 3 ...have the fluid level checked.
Old Apr 4, 2009 | 06:33 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
A whining noise from the tranmission, engine rpm dependant and starts only after driving a for a little while (10-30mins) are starts performing eradic shifts once it starts whining is a classic symptom of a blocked transmission filter. The whining is cause by oil stavation of the oil pump and the erractic shifts is caused by low oil pressure.
Drop the pan, drain the torque convertor if you have drain plug on it, replace the filter and add a magnet in the pan if you don't already have one. Refill with fresh genuine transmission fluid.
Repeat this preceedure in at your next service.
The usual cause of the blocked filter is excessive amounts of clutch linings in the oil from normal wear and tear. I can also be a sign that the torque convertor clutch is failing as this wears quite rapidly in comparison the the rest of the clutches.
If you change the oil, you have a good chance of keeping the transmission servicable for a while yet. If the transmission doesn't stop whining or starts again before you change the oil next then it's too late to salvage, time for a rebuild.
