My side mirror (driver's side) changed color.
Old May 27, 2009 | 12:55 PM
mistertonyn's Avatar
1999 E320 & 2008 S550 Designo
mister brenton....could you find out the part # please.
Originally Posted by Mister Brenton
Guys, you can buy just the glass from a dealer. It has a unique part number, although I don't have it off the top of my head.
I called the dealer here in Nor Cal and they don't sell just the mirror.
It would be great if you can find the part number for us.
thanks.
Old May 27, 2009 | 08:12 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Mother's clay didn't do anything to the gel streaks. I guess it's time to move on to bigger guns.
Old Dec 7, 2015 | 12:33 AM
splatter69's Avatar
c230
change color of side view mirrow
does anyone know how to change the color of the drive side mirror back to it's silver color
Old Dec 7, 2015 | 12:36 AM
splatter69's Avatar
c230
side view mirror color has changed
how cane you change the color back to silver
Old Dec 7, 2015 | 12:00 PM
nelbur's Avatar
1997 E300D
Yes, Buy a replacement self dimming glass. It will be clear silver, but be setting down when you price one. Aftermarket will be cheaper, but not cheap.
Old Dec 7, 2015 | 06:57 PM
splatter69's Avatar
c230
mirror changed color to tint
Originally Posted by mistertonyn
Has this happened to any of you? For some reason...oxidation or whatever.. the color of the mirror is now golden/brownish. I can still use the mirror but it is like having a color tint over the mirror. If I wanted to replace it...can I just replace the mirror it self? and how to you remove it? I hope it does not require the replacement of the entire side mirror assembly..other wise I can just live with the color change as long as it does not get worst and turn totally black on me.
My driver mirror has changed color to a tint color C- class (model of car c230). Is their a way to change color back to it's original color without replacing the mirror? HELP
Old Dec 8, 2015 | 12:05 AM
  #32
raymond g-'s Avatar
99 E320
the discoloration is the result of the auto dimming "electro chromatic" feature.
it is a gel compound sandwiched between the glass plate and mirror. in time,
it decomposes and leaks. the color change is the beginning of the death spiral
of this feature.
you can buy a replacement mirror and simply tape it on top of the existing mirror.
it may look half assed upon close examination. replacing the mirror by removing
the old mirror only takes minutes (on the 210)...less than 5 mins on my 1999
Old Dec 8, 2015 | 09:25 PM
  #33
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Youre in the w210 forum and also youre in a 6 year old thread. -_-
you own a w203...might want to check there in the future.
Old Dec 16, 2015 | 10:21 AM
  #34
renault12ts's Avatar
W215 CL500 2005
Does it matter...it's the same problem and the same answer.
Old Mar 8, 2019 | 11:21 AM
  #35
BMW side care's Avatar
BMW and Mercedes benz
My BMW , here to help you the best
May I know which car your using. ... actually this happens when you overuse your electronic side mirror adjusting or even if your side mirror have heat adjusters .. this doesn't affect the whole mirror .. it's only on its bottom surface expect the edge ... it's takes to remove the brown coat to be cleared for 5min in BMW -all models ... if any question I will be happy to solve it
