My side mirror (driver's side) changed color.
1999 E320 & 2008 S550 Designo
Has this happened to any of you? For some reason...oxidation or whatever.. the color of the mirror is now golden/brownish. I can still use the mirror but it is like having a color tint over the mirror. If I wanted to replace it...can I just replace the mirror it self? and how to you remove it? I hope it does not require the replacement of the entire side mirror assembly..other wise I can just live with the color change as long as it does not get worst and turn totally black on me.
i think that is the indication that auto dim is failing....the goo
mirror is affixed via snap fittings, wire retainer, as well as dbl stick tape so
you may need to use a flat bladed screwdriver/knife to carefully pry mirror
off from the plastic flange which is attached to the motor.
UPDATE 6/3/2020 = it appears the Youtube video link has dead ended. if you are needing
photos from a MB w210 showing exterior mirror removal, search Youtube as there are other
videos other than the one I shared (and which died). I may have still photos from my own
car though. If you need, email or PM me.
And the
auto dimming glass mirror is a pricey part,so unless you are really bothered by it or it starts to leak the almost impossible stuff to remove.Let it be,let it be,speaking words of wisdom.Let it be.
usaims
I did not realize the outside rear mirror had the
If it cost $400, then forget it...I can live with it...so let it be perhaps.
Please clarify...can I just replace the mirror only?
http://www.youtube.com/watch?v=Qn0bgoME_mQ
http://tinyurl.com/5vrvv4
Thanks Raymond.
I don't think its the "auto dimming" , I think its the oil used in the heat portion of the "heated mirrors".I had mine leak all over my drivers door and as ohlord stated, it isn't fun to get off.If you don't want to pay to have it replaced ,stop by a glass shop and have them cut you a replacement piece and attach it over top the old one.I wouldn't compromise my safety by trying to navigate with a cloudy drivers side mirror.
That is a good idea, but will it look too thick and funny ?
I would imagine that 3M makes a high bond adhesive that should be available at Pep Boys ,Auto Zone etc.If you are going the mirror-over-mirror route , I would also consider scruffing the surface of the old mirror up with sandpaper to insure proper adhesion.
autohausaz has the mirror for $248 for production models through 6/1999. For models produced from 7/1999 on the price is $598. Wow, that's a huge difference.
Holy smoke!!!
I'll just take the mirror over mirror route...should be much cheaper...but I won't have the auto dimming feature any more
you're going to cry more when I tell you that i sold a mind condition OEM
mirror with autodim for $75 shipped several months ago to a forum member.
still have one more but that'll be my personal spare. did you check your
local auto wrecking yard? worth a call(s)
If you're still in need of one and you have a facelift model W210, fleaBay has one for a decent price:
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWDVW
OR you can opt for eurospec blindspot mirrors. I replaced my OEM ones for these. Granted, there's no auto-dimming feature; I was willing to part with it.
http://cgi.ebay.com/ebaymotors/MERCE...spagenameZWDVW
Inexpensive option
very good to know...
1 Post
'06 E 350 4matic wagon; '05 E 500 4matic sedan; '09 S550 4matic
I had the jerk at the NJ inspection station fail me for "bronzed mirror", no crack or external leaking, just the slightly darker tint. I didn't want a non-standard paste over, etc. so allowed myself to get the fleecing from the MB shop- $400+.
Luckily they don't inspect for that in CA.
since mine is bronze as well...I can still see through the tint without any problems as long as it does not get any darker
Ouch on the $400+ bill for a side mirror.
'99 E430, '05 ML500, '15 GLK350
How to get rid of the mirror goo?
Mine finally gave out and drizzled down the door. It looks like it ate some of the paint on the mirror housing as well.
What's the best route for removing this crap? Soap and water didn't do much.
Thanks.
Thanks.
2003 S210 3.8L Brabus wagon
I bot mine for a post face lift car from Autohaus for around 328 last year versus the dealer wanting $607 plus labor. The post face lift mirror glass is an easy pop out and pop the new one in with two small electrical contacts that plug in and out. It is the liquid used for auto dim that goes bad. It chemically breaks down and the seal erodes and then begins to leak. If your mirror is changing color you may have a few more months before you will be dealing with a big mess. Bite the bullitt an get it taken care of now. Glass shops simply use a precut mirror made overseas (not a good fit and looks lousy) and some windshield sealer glue to do the paste over. I, like all of you facing this, tried that first and immediately had them take it off before I left their yard. It looked like sh#t and like something you would do to a 1980s piece of #### clunker that you did not care about. As for the goo try bug and tar remover or or go stronger and use the Purple cleaner degreaser. It will remove the wax and oils from your car so a good wash and rewax after is on the agenda.
Update on mirror goo
The electrochromic gel (proprietary product of Gentex) had solidified pretty well on the paint before I could get to it. About an hour of vigorous fingernail scaping and rubbing with 3M Performance Finish got it off the driver's door, but there are some residual stains in the clear coat.
Not sure what I'll do on the clear coat stain - any ideas?
3 inch random orbital polisher from Griot's garage and some lens polisher paste then 3 step prep and wax from Mequiars. The polish is amazing. Clay is good for pulling debris out of the painthowever, not sure about a stain that might have eaten into the clear coat. Never hurts to try though. Just function of time and ah little mo money.
hey!....was googling around and stumbled across this. who wants to be the
guinea pig with this vendor? it doesn't mention the autodim, but I'm intrigued
by the low cost.
by the low cost.
