Is it possible to retrofit a COMMAND on a 97 E420?
HI,
Can anyone tell me is it possible to retrofit COMMAND into a 97 E420? There is no fiberoptic used in 97 E420 and I think the COMMAND needs a fiberoptic system? Correct me if I am wrong.
THanks
Ed
THanks
Ed
209/W210 Estate /W211 modded by MBENZNL
Comand Install
Yes You can Install The Comand Into a Early W210
You will need the Correct Comand,Replacement wood,The Cage,And Misc Pieces for the Install
Please contact Steve @www.MBenz.nl for prices and Install Info
C230K and ML320
Re: Is it possible to retrofit a COMMAND on a 97 E420?
Originally posted by cabby850
HI,
THanks
Ed
HI,
THanks
Ed
Dave
Former Vendor of MBWorld
some slow@$$diesels
Installing comand in any W210 E-class is a 4 hour job...max...and everything WILL function (egardless what your dealership tells you).
I installed 3 210 comands sofar and have 4 to go (of which 3 within days from now).
greetingz,
greetingz,
2000 E320 4Matic
Boston?
Steve - will you be anywhere near Boston soon to do Command installs? I want to have you do one for my 2000 E320 4matic. Tell me what you need from me. Have pic available if you need for wood.
some slow@$$diesels
Originally posted by hubert
How much will it cost to insstal comand on a 1999 E430.
Hubert
Hubert
greetingz,
COMMAND installation in NY?
Hi Steve,
I have a 97 E420 and I live in Queens, NY. Would you be able to install COMMAND for me when you are in NY in May?
Its $1300 installed + $250 Wood piece. Does that include a Fiberoptic CD Changer? Is it possible to watch DVD with the command you are installing? Would I need to purchase an additional Mobile DVD player?
Please let me know when you are in NY area.
Edward
Edward
some slow@$$diesels
Edward,
Please do a search on this forum about comand and mail me (after you have done some research) at s_krabbenborg@hotmail.com
greetingz,
greetingz,
