Headlight switch problem
Old May 7, 2009 | 01:49 AM
MR888's Avatar
E55
My driver side headlight does not work properly, I figured out it was the fuse not sitting right in the headlight switch fuse box, I curved the fuse endings a bit with pliers and it worked for a bit but now it went out fully, just wondering if all W210 headlight switches/fuse boxes are interchangeable so I can get a used one of ebay?
Old May 12, 2009 | 08:25 AM
230TErry's Avatar
93 320CE, 72 280SE 3.5, 55 220A, 05 E280CDI, 88 Mini Mayfair, 90 Peugeot 205GTI, 04 Mini Cooper
Not sure but seems to be common issue with fuses.
Where are you based?
Old May 12, 2009 | 10:48 AM
ohlord's Avatar
Solder
in a jumper and insert an inline fuse and tuck it into the box.Easier than finding and paying for a new switch and installing it.
Repair about 50cents for the inline fuse holder
Old May 13, 2009 | 10:23 AM
MR888's Avatar
E55
Arrr wish you would of responded a bit sooner, I already bought the switch on ebay a few days ago, only cost $30 so its not bad. What do you mean by jumper ? I wouldn't mind a temp solution until the switch arrives. Thanks
Old May 14, 2009 | 12:06 PM
MR888's Avatar
E55
Picked up a inline fuse holder and tried connecting the ends into the internal connectors with no luck, I guess the connectors for that fuse are done.
Old May 14, 2009 | 01:27 PM
ohlord's Avatar
If the fuse holder
is bad,why are you r/r ing the switch?
Replace or fix the fuse holder.
Old May 14, 2009 | 01:47 PM
MR888's Avatar
E55
lol, I looked up the part and its $300 at the dealer so I think its fine how would I replace the internal fuse connectors anyway?
Old Jun 2, 2009 | 05:18 AM
MR888's Avatar
E55
Installed the head light switch that I bought off ebay for $30, which came off a E430 and had a different part number, all works well
Old Feb 12, 2023 | 03:49 PM
richpilot35's Avatar
1997 E-300D
2009 E 350 headlight switch does not light up
The headlight switch on my 2009 E350 does not light up. Does anyone know if I have to replace the switch or is there a way to replace the bulb inside it?
