99 E320 won't move after replacing wheels
it took a long time to tighten because they are too long. the back end of
the lug has reached too far out the back side. any attempt to drive the
car will result in serious/$$. stop right now.
follow up: according to my notes, match the proper size ball or taper seat
with the proper lug bolt, then select a lug whose shank length protrudes from
the back of the wheel by at leat .5" but no more than .75". if you pop off
your rim now, i'll wager that you'll measure about an inch or more ¿
each wheel is likely to have differing thicknesses between the bottom of the
ball seat-to the back of the mating surface of the wheel. this cross section
determines the length of bolt you need.
so answer the above question and we'll go from there, e.g.
- was the new rim designed for MB fitment?
- have you verified that the center bore is 66.5 mm?
- does the new rim use ball seat lug bolt (if so, what size)?
- does the new rim use tapered seat lug bolt?
- what is the ET?
- what tire size does it have?
hmm, you mentioned another important clue which has be concerned.
it is possible that the rims you have are made for 14mm diameter bolt
which is why the supplied bolts were 'too large'. if so, this may also
mean that the ball seat has a 14mm radius.
by substituting your stock bolts, you're short changing the contact
area between bolt and wheel. reference this old post - - > click
so this or that for hybrid bolts to fit
Many aftermarket wheels use cone seat lug bolts while the Mercedes OE bolts are ball seat. You really should use not only the correct length, but the right seat and diameter bolt.
I would send an inquiry to the wheel manufacturer (with whatever number you can write down from the wheel) and ask.
You can find the right length pretty easily.
Use your Mercedes wheel and lugbolt. With the wheel off the car, stick the bolt into the hole. Measure the length of the bolt on the back (sticking out). Now you know how much should be sticking out on the back. Then do the same with the aftermarket wheel and put a mark on the bolt at the same sticking out point. Withdraw the bolt and measure the length.
If the wheels have gone around once, then the parking mechanism is damaged.
44 et is way off,stock is a 41.WIDER TIRE MEANS LOWER ET,you should be on 35's Et wise maybe even a 31 et on the front. Measure the lugs and order a set of the proper seat and size from rad/otis usa they will have ones for your app.
The rear lugs have engaged the e brake that is why you can't move it or move out.
ET phone home
Me still in Iowa, working on a forum members collection of Mercedes and having a blast. One of the nicest families I have ever met in my life.
Peace radiates from everything they do or touch.
