W210 E320 Replace bulbs in center console AC/Heater control display
Old 06-08-2009, 05:06 PM
smlusci's Avatar
1999 E320 1989 560SL
The bulbs in the center console AC/Heater control display need to be replaced. Is this something that can be done DIY or must dealer use special tools to do so?
Thx
Old 06-08-2009, 09:28 PM
SLOPESTAR's Avatar
99' E320 4MATIC ESTATE / 92' 190E 2.6
SEARCH! SEARCH!! SEARCH!!! ITS BEEN DONE AND DOCUMENTED BY MANY! I KEPT ASKING AND HAD TO FIND OUT THE HARD WAY!
Old 06-09-2009, 07:14 AM
smlusci's Avatar
Cool
WOW - thank you so much for your help.
Old 06-10-2009, 10:12 AM
KADE's Avatar
year 2000 model E-320 210 chassis
I think they may have the DIY article on benzworld...Don't know if your registered with them also...but most are..check and see.
Old 06-10-2009, 11:21 AM
Karachite's Avatar
2001 E320
Wink Center Console control display bulbs replacement
Obtain the Mercedes Dashboard Service kit from HarborFreight.com for $3.87 + shipping.
Enjoy
Old 06-10-2009, 03:14 PM
ohlord's Avatar
Give the guy
a break
You get the keys for the radio/climate control module removal
From hb or someone that sells them(mb)if you can't wait,or find a member nearby that has them. Insert them in the slots at the bottom of the module and pull it out, flip it over, twist out the little socket and replace the bulb that you need to order from the dealer or www.autohausaz.com, reinstall newely lit climate control cluster.
There. Your very own diy.
Don't have the dealer do anything
You your own self can do it all
Old 06-11-2009, 07:38 AM
smlusci's Avatar
THANK YOU! olord, karachite and kade - Will check those out.
Quick Reply: W210 E320 Replace bulbs in center console AC/Heater control display
