Power steering fluid
I'm going to the dealer to buy some fluid tommorrow, can I just fill it to proper level, or do I have to drain or pump out the old fluid. I'm asking this because this is 98 E320 and I want to make sure that it's ok to the mix the new fluid with what is left of the old fluid?
usaims
When you have it repaired then you bleed it to remove all the old fluid and get the air out.
Find an indie if you don't diy. Do not take this one to the dealer
For warned is for armed.
1.1 us quart
