dashboard buttons? key fob tricks?
Also, I was told that you could roll down and roll up windows remotely (presumably to air out the car on a hot day) using just the key FOB. How?
Thanks...
Manual posted in the diy section on www.benzworld.org
w210 section
I back doored the MBUSA and got links to pdf manuals for most models back to 2000.
service manuals also.
If I recall, up and down buttons set display brightness when the headlights are on and the R resets the odometer. It's been a while, though.
w210 section
Thanks...
IR operates lock/unlock and the window open/close
So when you click lock, it sends both an IR and RF signal. When you hold it to close the windows, it only sends an IR signal.
There's undoubtedly an engineering/cost reason, but the idea is for security. If you accidentally hold the unlock button in your purse/pocket, the RF will unlock the doors. After a minute of not opening the doors, they'll automatically relock.
If it opened the windows by RF, it would also have opened the windows. And they would stay open, without you knowing. And it would be obvious they were open, versus the door lock which no one really knows.
Thanks...
With your car key in your hand, within a few feet (mine working only 10 feet or less), hold close button, all the windows & sunroof will close until you release the button. Same true with OPEN button (approach the car on a hot day, hold the open button, all the windown will roll down, then the sun roof will open (window open first, then sunroof) so the heat will get out before you start your car.
