ignition switch removal
Old Oct 12, 2009 | 05:00 PM
dirtbag_700's Avatar
97 e420
hi everyboby,need some help removing ring around ignitin switch,
i am trying to install a remote starter and i believe the imobilizer is behind it and i need to install a bypass coil behind it if possible
thanks ,any help would be appreciated
Old Oct 12, 2009 | 07:14 PM
ohlord's Avatar
You won't do it
the rolling code is inductively transmitted via the Ir in the key to the das to the ecu.They are all married as a complete system to the tcu.
You are playing with fire and if you shoot the das system it is going to cost big bucks.
I for one wish you well
Old Oct 12, 2009 | 07:17 PM
ohlord's Avatar
I see you have an orphan
E420 look on www.peachparts.com for tool pins and removal procedure.
Early model with blade key ignition you might get it done without frying anything.
I hope
Old Oct 13, 2009 | 03:27 PM
97 e420
thanks for the link,got it figured out
