Check Engine Light Codes....Help?
Old Oct 26, 2009 | 11:27 AM
Jagster's Avatar
2000 E320
My check engine light is on and had the following codes read:
P0173
P0170
Can anyone tell me what needs to be fixed?
Old Oct 26, 2009 | 11:42 AM
tirona's Avatar
1997 s320, 1997 e320
do a search on "maf" or mass air flow sensor. your codes point at maf.
Old Oct 26, 2009 | 11:45 AM
ohlord's Avatar
Replace
the mass air sensor.It is failing and out of range.
Cleaning helps at times. procedure on diy section www.benzworld.org w210 forum use only crc brand maf cleaner sold at most good auto stores.
new maf www.autohausaz.com about $160 delivered takes ten minutes to install.
Old Oct 26, 2009 | 02:41 PM
Jagster's Avatar
2000 E320
Thanks for that. I cleaned it out and cleared the service codes and will drive a few days to see if it pops back up.
Old Oct 26, 2009 | 06:28 PM
Jagster's Avatar
2000 E320
Will it cause more damage if I drive with a bad MAS?
Old Oct 26, 2009 | 08:42 PM
ohlord's Avatar
No
not in the short term.
If cleaning worked the codes won't come back. If they do time to replace it but no hurry.Just order the new one and install it when it arrives.
Old Oct 29, 2009 | 12:26 AM
armaniE55's Avatar
2012 CLS63 AMG
Ohlord! Hope all is well..
He's correct clean MAF.... but 90% chance your CEL will go back on .. No rush I waited out for 5 months before I replaced.. German Star Insert (cheap)
But what I will say is I defiantly robbed myself from HP... Nothing like a fresh MAF..Your car will love you plus my gas mi up
Armani
Old Oct 29, 2009 | 02:56 AM
ruBENZ's Avatar
2000 E55 AMG
P0170 + P0173 is definitely a failing MAF sensor. Even if you clean it, it is still a failing MAF sensor. Replace it, and your "buttometer" will thank you.
Old Nov 25, 2009 | 11:12 PM
maksi's Avatar
2020 GLC200 (X253) 1995 mb W202 C220, 2008 Mitsubishi Lancer Evolution, 2014 Ford Mustang 5.0
P0173
P0170
dude,
P0173 means Fuel Trim Malfunction (Bank 2)
P0170 means Fuel Trim Malfunction (Bank 1)
hope this helps.
Old Nov 25, 2009 | 11:33 PM
ohlord's Avatar
Dude
We all know what the codes indicate.Being helpful is telling him what those indications point towards as a solution.
