Need to know which VSS sends signal to Tran Con Sys
2000 Mercedes Benz E320
2000 E320 Sedan goes to Limp Home mode had diagnostics done was told it was the "" Front and Rear Speed Sensors and "an audible signal which means it needs rebuilding the transmission" ("starting at $2800"). When I asked for the codes I was told that he never saved them. I want to try changing the speed sensors first but I am having a problem locating them. Can anyone send me a diagram or something that shows which VSS would send a signal to the transmission.
Get to a different
shop. Have the electrical connector checked for leaks.
Diy on www.benzworld.org w210 diy section 722.6 electrical connector leak.
Start there.
Start there.
