99 E430 PROBLEMS
Old Oct 30, 2009 | 04:20 PM
Ghostsamurai25's Avatar
1999 E430
99 E430 PROBLEMS
Hi, I have a few problems with this benz, it has 125k miles and has been garage kept. First problem is the ac wont blow cold air, I had reset the system so that the ec light would go off and still nothing. Any help with that would be appreicated greatly.
Second issue that just started is the outside lights will start to flash as if the alarm is going off for no reason. I dont want that to kill the battery seeing as its a pain in the *** to recharge it or to have benz come out and change it.
Third issue is the rack and pinion. Its leaking and benz wants 1300 to buy the part, autozone has it for 400, do you guys recomend the auto zone parts, why or why not?
So there it is, once I fix those things this baby will be up and running until then its just a drive way ornanment
thanks for any advice.
Old Oct 30, 2009 | 05:54 PM
ohlord's Avatar
What's
leaking on the rack?
The boots are replaceable.The whole unit from a real mb supplier is about $450 rebuilt.I would stay away from autozone for that unit.
Did you check the charge in the a/c?
Did you run the ob diagnostics?
Check all the door strikers,if out of kilter the alarm system thinks a door is ajar
Old Oct 30, 2009 | 07:09 PM
1999 E430
Thanks for the response. The leack is coming from one of the seals close to the passenger wheels, two mechanics told me the whole unit needs to be replaced Can you steer me in the direction of a good online part store for these cars, Im use to infinitis and would order from everything infiniti.com original parts at a fraction of the dealer prices. Not too big on the whole using funny parts from funny site thing.
I did run the diagnostic a few months back and had no clue what to do with those numbers kinda like reading french. Ill post them and maybe you can make more sense of them How do I know if I have freon in the car?
Ill do what you said about the door jams and let you know how it goes.
Old Oct 30, 2009 | 08:00 PM
ohlord's Avatar
Rack get
quote from www.autohausaz.com
or www.peachparts.com
you will need to run your vin or have it handy so they know if your car had parametric(sp) steering or not.
autohausaz usually has the lowest prices and free shipping on oem and oe parts.
They also have the boots.
Charge best to have a shop with proper gauges test it,if the compressor is running you can check pressure but not charge since it is a variable demand system.
Check that nobody jammed a seat belt in the door and knocked the striker out of the original position.
