Just bought my 01 e430, thanks everybody for your help GOT 3 PROBLEMS...............
2001 E430
1. when coming to a stop, going from D to P is really hard, car seems stuck in D its like you have force it like crazy or find the perfect spot too put it in P.
2. ESP light is flashing
3. BAS light is flashing
one of those is solid yellow in the bottom right corner.
any help will be appreaciated
2002 E430 4MATIC
If you start the car with foot OFF the brake, do you still get the flashing ESP/BAS?
BAS/ESP are likely the brake light switch. Not positive about the P/D difficulty but these cars are EXTREMELY sensitive to the shift selector getting wet. Very easy to ruin the shift selector module with a little spilled water or coffee or even leaving the sunroof open in the rain....
Check the shifter bushing connecting the linkage to the shifter under the car.
How's your battery voltage? Key on, press and hold REST for 5 secs, use AUTO buttons to toggle to screen #24, should be +13v while running.
Dead battery lately? If so, start engine, turn steering wheel lock to lock a couple of times.
93 320CE, 72 280SE 3.5, 55 220A, 05 E280CDI, 88 Mini Mayfair, 90 Peugeot 205GTI, 04 Mini Cooper
Check your fuse in the panel in the side of the dashboard it can give similar problem.
The fuse or board can be faulty. The fuse board is part of the headlight switch.
2001 E430
