BAS AND ESP SIGN ON DASH?
Old Dec 29, 2009 | 03:25 AM
stunna202's Avatar
02 c240
What does it mean
it keeps flashing on my dash...
BAS AND ESP
someone pls explain
thanks
Old Dec 29, 2009 | 03:26 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
more than likely the stop lamp switch has failed.. I'd find somewhere to pull the fault code and make sure though..
Old Dec 29, 2009 | 09:33 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
It can also be one of the early signs that the battery is failing. Especially if it comes on and then goes out after one or two drive cycles. If it's the battery, you may also experience loss of sync on things like express windows and sun roof.
Old Dec 29, 2009 | 09:19 PM
stunna202's Avatar
02 c240
thanks guys, by stop lamp u mean brake lamp?
Richard, ill get my battery checked tomorrow , maybe thats why my sunroof and rear sunshade is not working
BAS means?
ESP means?
Old Dec 29, 2009 | 11:01 PM
RichardM98's Avatar
I believe he is referring to the brake switch located under/behind the brake pedal. It is common for the BAS light to come on when the switch becomes defective.
See here:
http://www.benzworld.org/forums/w210...lly-fixed.html
FYI, the best way to test the battery is to remove from the car and do a load test with the battery on the bench.
BAS means?
Brake Assist System - This system anticipates an emergency braking action and deploys full pressure faster than the driver can.
ESP means?
Electronic Stability Program - This system uses wheel speed and steering yaw to modulate braking and keep the car as stable as possible during emergency events such as hard cornering. This is an extra cost option. Most cars will have the ASR (Acceleration Slip Regulation) system.
Old Jan 12, 2010 | 01:36 AM
In2MB's's Avatar
10 MB S550, 07 MB S65, 07 S600, 03 MB S430 Graphite Designo, (Sold w/227k miles)99 E430
Could be the Brake light switch
My aunt had the same exact problem with her 2000 E320 last month. The BAS and ESP would come on periodically. When she took it to the service department they told her the brake light switch needed replacing. Since the switch was replaced she hasn't had the problem.
Old Jan 18, 2010 | 01:17 AM
stunna202's Avatar
02 c240
and where is this brake light switch located?
Old Jan 18, 2010 | 08:27 AM
saintz's Avatar
GL450
DIY instructions:
Old Mar 4, 2013 | 10:58 AM
billbillw's Avatar
2001 E55 AMG (sold)
I've been having the BAS and ESP errors (but not the ABS) come on occasionally after my car sat over a long, cold weekend. I know its not the brake light switch because I just replaced that a few months ago. It always seems to go away if I restart the car.
Most likely my battery getting weak? Haven't noticed any sync problems yet.
