Floppy side mirror ( w210 ) fix
you'd be able to do it easily thereafter. the video is done, naturally, under
the most ideal of conditions.
another example would be showing you how to use a slim jim to unlock a
car door. done by touch and envisioning where the parts are which need
to be jostled into compliance.
first time i tried this on similar latch like yours, it took me 2+ days.
thereafter, about 5 mins.
with the pre-facelift, wire latching system, it's more like seconds.
I have spent almost 3 hours to get the mirror housing off my 1998 e320. I just can't seem to pry that wire off the tabs. I've watched the video about 12 times and I'm thinking maybe that mechanism is different for the '98 e320 - yes/no?
Do I just keep at it until I break something off - lol?
Would appreciate photos if anyone has any.
Cheers.
if you're having difficulty, how about you post pic of the inside of your mirror?
that way, others can see what we're trying to solve.....as oppose to presuming
your's matches what is in our heads?
this is a much better approach....as I've seen one other variation for a 210
which was from a euro or non-North American car
That should free the cover.
I can't check mine as I have sold mine early this year.
at the same time you (or someone) apply pressure to the cover
http://oi55.tinypic.com/25juyl3.jpg
you simply need to move the spring loaded wire (on both ends) in the direction
of the yellow arrows....
...to clear the plastic nubs molded into the inside of the cover (green arrows)
and the cover should easily pull out
can fracture if pressed hard enough. i've not heard of anyone on the various
forums report that they've broken this part.
as a gauge, i would say it can easily handle 10 lbs force on 6" screwdriver.
it's very unlikely that you'll deform the spring wire latch unless you put your
shoulder muscle into it
Thanks for the tip.
My mistake was I wasn't applying pressure to pull off the mirror housing so the retaining wire would spring back behind the tab.
Once I applied pressure AT THE SAME TIME as prying the pin off of the tab, the housing came off without a hitch.
Once I got the mirror housing off, I noticed that the hook upon which the spring is fixed to is broken.
I used a simple zip tie to secure it against the mirror as per the suggestions in this forum.
Thanks men . . .
You just saved me $1000 - that's how much the Benz Stealership quoted me to completely replace the mirror.
Eternally grateful to you all and people like Raymond.
You can check it out here and if you're interested let me know.
www.CashFlowGPS.com
This way you don't have a weak point with a screw, jb weld, or a zip tie.
I see the last post was quite some time ago. I just recently had a floppy driver side mirror, and I am so glad I found this forum. I made the repair but now I am having problem putting the housing back securely.
I will use the picture that Raymond G posted on 08-28-2011, 09:43 P. The two ski ramp looking tabs are now kind of far from the wire (yellow and red circles). I can't figure out why that is. My question is that there is a yellow line on the right of the picture. Does the black tab where the lower yellow line is point need to go into the white latch where the top yellow line is pointing?
I appreciate any feedback on how to reinstall the housing.
Thanks a lot.
Without this help I would never have been able to repair the damage done by my local car wash! Nelbur, you're a star
The detailed DIY is as follows:
1. Adjust the edge of the mirror nearest the door so that it will clear the cover when it is removed ( about 1/4" recessed).
2. Push the mirror back against the door and look into the workings. You will see a wire bail that holds the cover on. pry the bail from behind the tabs on the cover and carefully pull the cover off. (see pictures, the bail is on the right side).
3. You will notice that the spring end is not attached. If the attachment hook is bent over, break it the rest of the way off and get it out of the way.
4. The fix is to take an 8 or 9 inch piece of "noncorrosive safety lock wire" and run it behind the mirror backbone (go under the electrical wires ) and run it through the end of the spring, and back by the front so the wire ends can be twisted together. (see picture one)
5. Grab the twisted end with a standard plier, pull to stretch the spring and twist the wire. Repeat pulling, then twisting, until the twisted wire has pulled the spring back to near where it was before the hook broke. Clip off the excess twist and bend the end up out of the way of the cover. ( see picture two). I added a second wire to share the load.
6. Carefully slide the cover back on. Make sure the tab, seen to the left of the wire twists, fits into the receptical in the cover. The cover should snap in place as the bail pops behind the tabs on the cover.
Just a comment on "safety lock wire". This is a stainless steel wire used by car racers and aircraft mechanics to secure critical bolts and other parts. It is designed to be twisted without breaking the way regular wire will when tightly twisted. It is available at Harbour Freight for small money. It has a thousand uses in any shop.
Havent found any youtube vidz for W210 - thanks!
see "mirror, outside, repair tips"
it is possible to do this without removing the cover but i dont recommend this
as it is also possible that some damage will occur. sup, brah !
I knew i could count on you bruddah
Thanks man... i actually got it out w/o removing the entire unit or cover. BUT....the unit i had was slightly different and had diff wiring connectors. So i installed w/o electronics...but at LEAST I CAN SEE IN IT NOw !!!
Thanks,
Nick
1999 E430
