Floppy side mirror ( w210 ) fix
The detailed DIY is as follows:
1. Adjust the edge of the mirror nearest the door so that it will clear the cover when it is removed ( about 1/4" recessed).
2. Push the mirror back against the door and look into the workings. You will see a wire bail that holds the cover on. pry the bail from behind the tabs on the cover and carefully pull the cover off. (see pictures, the bail is on the right side).
3. You will notice that the spring end is not attached. If the attachment hook is bent over, break it the rest of the way off and get it out of the way.
4. The fix is to take an 8 or 9 inch piece of "noncorrosive safety lock wire" and run it behind the mirror backbone (go under the electrical wires ) and run it through the end of the spring, and back by the front so the wire ends can be twisted together. (see picture one)
5. Grab the twisted end with a standard plier, pull to stretch the spring and twist the wire. Repeat pulling, then twisting, until the twisted wire has pulled the spring back to near where it was before the hook broke. Clip off the excess twist and bend the end up out of the way of the cover. ( see picture two). I added a second wire to share the load.
6. Carefully slide the cover back on. Make sure the tab, seen to the left of the wire twists, fits into the receptical in the cover. The cover should snap in place as the bail pops behind the tabs on the cover.
Just a comment on "safety lock wire". This is a stainless steel wire used by car racers and aircraft mechanics to secure critical bolts and other parts. It is designed to be twisted without breaking the way regular wire will when tightly twisted. It is available at Harbour Freight for small money. It has a thousand uses in any shop.
What is the recommend size of the wire to use. > .025 or < than .025. The only place I can find the Stainless Steel Lock wire is online. I want to be sure I order the right size for the job.
Yes, i have a C class. The pictures look the same so this fix should work.
however now I have another problem...the position memory is not working anymore. At first I thought I had to re-program the mirror position memories again.....so I did that. But even after doing that the mirror does not remember its position.
It overshoots and goes all the way to the end of the travel and then keeps going on! It hits the stops and makes a tick tick sound and the mirror jerks against the end stops
I think there is some position sensor which is damaged or needs to be cleaned.
Any tips?
Great writeup. My mirrors became loose after some autobody work. They must have tried to remove the covers for a paint touch up job and brooke the spring hooks. I used zip ties to secure my springs.
I have a 2000 320CDI with turn light in the mirrors.
I really cant see this tingy to flip to remove cover.
Sombody has stolen both my mirrors so I should just pop the new ones in, but aint that easy.
I have taken some pictures:
https://picasaweb.google.com/chris.ulriksen/Bil#
I really cant see where to open it.
Someone have stolen both my mirrors.
for both 96-99 models.....as well as 00-02
Not the long thin one and not the shiny small one.
Might be just me thats blind.
It should be a 00 mod.
try going underneath like I did one time on a stubborn latch. look for the
PDF i posted with pics, showing the angled screwdriver i used.
