Code 02
Old Feb 15, 2010 | 12:35 PM
Palermo Len's Avatar
1999 Mercedes E320 Wagon & 1927 Bugatti Kit Car
Code 02
Any idea what triggers code 02? the chart says "Fuel Volume Regulator Control Circuit Range/Performance". This is Greek to me, what do I look for?
Old Feb 16, 2010 | 01:03 PM
ohlord's Avatar
Code 02?
if you have an obd2 scanner plug it in and get the 4 digit obd2 code if you have a check engine light on.
should read P****
Old Feb 16, 2010 | 02:25 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
He did. It's P0002.
I think he's asking for help explaining the DTC description he's posted.
Old Feb 16, 2010 | 06:54 PM
Originally Posted by RichardM98
He did. It's P0002.
Yes, this is what I am asking, please forgive my lack of explanation.
Old Feb 16, 2010 | 08:13 PM
RichardM98's Avatar
Well, if anyone knows what it might mean, it's him.
BTW, was this a pending code you found or was the Check Engine Light on? If it was a pending code and the car seems to be running fine, just erase it and then check after to a few driving cycles to see if it comes back. Often they don't.
Old Feb 17, 2010 | 12:28 PM
Yes, the check engine lite was on which was due to the 2 other codes indicating that the MAF sensor needed replacing. I have been cleaning the MAF sensor and erasing the codes several times and now I replaced it with one purchased from Autohaus. Now I am hoping that that ends the CEL problem but I still don't know what the P002 code was and it probably won't reappear but I wanted to be prepared if it should return. Thanks for all your help.
Old Feb 17, 2010 | 12:56 PM
RichardM98's Avatar
Interpreting the codes is a experience driven process. Also, the code errors sometimes cascade. That is, a code for one error trips a second error which would not have occurred except for the first. So you may not get the P0002 after the MAF replacement.
Good luck.
