cluster Analog stays on?? batt dead??
1 Post
ml/e420/others
anyone has this prb? had to jump my car this morning and again around 7pm
my car has no aftermarket system cables/aftermarket alarm etc..
98 Brilliant Silver E320 Wagon
OK. You mean the digital display in your instrument cluster? If it stays on continuously the system may believe the key is in the ignition. When you turn off the engine, remove the key and open the door do you get a 'Key in Ignition' warning?
If you haven't done so I would try disconnecting the battery ground for a few minutes and then reconnecting to 'reset' the computer system. Be sure you have your radio code before hand.
If you fully charged your battery (and the battery is healthy) and it went dead in just a few hours it sounds like a leak to ground in some circuit.
1 Post
ml/e420/others
i notice when talking out the back seat to disconect the batt i had closed the door and the bottom door lights stays on also.
i have the radio code so should i still disconnect he batt and charge the batt and reconnect?
as far as the key when i turn off the car it beeps then when i take it out it stops
thanks on the help.
thanks on the help.
I'm a little confused by the 'symptoms' but I'd suggest that at this point you eliminate the battery by having it removed and have someone perform a load test at the bench. If the load test shows the battery is okay have it fully charged and reinstall. That will also provide a 'reset' to the CAN.
These cars are sensitive to voltage level and when the voltage gets close to the threshold strange things start happening like bogus error messages, etc.
97 E420 90 300E
I'm going to bring this back from the dead. What did you do to solve this problem? I'm having the same issue with the puddle lights on the bottom of the doors not turning off. I just put a new battery in it 3 months ago. I went to start it today and the battery was dead.
Its weird, I thought it was a door switch at first but all the doors turn the dome light on and off when I open and close the doors. But these dang lights are on all the time. Anyone dealt with this before?
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Well if you are absolutely sure that with all door switches taped shut your interior lights are still on bla bla then there are three other areas that could be causing the problem-door control modules, PSE or the overhead control module.
Your problem is that you do not have the diagnostic tools to quickly examine the extended vehicle network to locate the fault. That takes DAS Xentry or equal!!
