RPM FLUCTUATION.
<o:p></o:p>
Like it’s not really that bad but I am concerned. My 2 sense tells me it could be either the motor mount going bad, or the catalytic converter is clogged up which could reverse the emission back to the engine. <o:p></o:p>
<o:p></o:p>
Some guidance.. cuz I really love my e420 and I don’t want it to give up!!<o:p></o:p>
You might start by scanning the car for OBD II codes. You can get a fairly inexpensive scanner at Harbor Freight. Follow the directions and write down the codes which have the form P0xxx where xxx is a 3 digit number. Next clear all the codes with the scanner (some maybe just transient). Go thru a few drive cycles over about a week. Now reread the codes. Post them here for help with interpretation.
Good luck.
use CRC mass air sensor cleaner.
After I drove more than 200 miles was when I noticed the RPM fluctuating... <o:p></o:p>
The guys at the shop gave me an injector cleaner and fuel line cleaner they believed that since I drove all those miles it may have clogged the fuel lines a little.<o:p></o:p>
Long story short it doesn't fluctuate but I am still going to clean the MAF to be on the safe side as well. After this my next task will be... (the one and only CATALYTIC CONVERTOR drama) dun... dun.. dun... <o:p></o:p>
Tell us about the CATS - which ones did you use? How were they installed, which O2Sensors? Big job here. I've been living with rattles from mine and with summer coming it will be noticeable with open windows. Indy thinks it might be the shields, but once he cuts those off I may have worse problems created from the heat. That worries me about any replacements I have seen.
So how is yours?
