Help me troubleshoot fog light problem
and test power to the socket.
Or you can back probe it with a test lamp.
Sockets go bad,harness for fog wires are known weak points,and you are correct start with the fuses
list of which are on the slot by the battery or on www.benzworld.org w210 diy section.
MB makes a repair kit for the fog light harness which includes socket and pigtail. Part No. A000 540 21 05 About $35-40.
Good luck.
And poster above is cdorrect about the upgraded harness for the fogs,but check the power and the socket condition before going down that path.
Sorry, Friedolin, I was referring to fog lamp not head light as your post mentioned. I'm not aware of a repair kit for head light and generally those wiring harnesses are not a problem unless someone replaces stock bulb with higher wattage.
