97 e320 rough start when warm
I got the sparkplugs replaced at the dealer and shortly after, maybe 2 months or so, I stated having an issue with a warm start. Cold starts in the morning or at any time for that matter are no problem. here are the symptoms:
1. a need for excessive cranking to start.
2. once it turns over, it stutters at 200-300 rpm for 0.5sec and then shots to 1500 or 2000 for 0.5sec and then returns to normal idle.
3.some times it turns over and immediately stall.
4.I have no codes for the ignition of fuel system. (checked with carsoft)
once the car starts there is no stuttering or issues at all. the entire RPM band is nice and smooth and so is the idle.
IDEAS:
1. I ruled out a sparkplug issue since they work better when warm and the issue only appears when the engine is hot.
2. I also ruled out a fuel issue since I repliced the fuel filter and checked fuel pressure. also a fuel issue would present itself throughout the powerband and also in could starts.
any info is greatly appreciated.
thanks.
Thanks for your reply. it is very appreciated.
I keep getting the same answer everywhere I ask but I also hear that it is a very rare part to go out on these engines. I have found many DIY for the V6 and V8 but nothing for the L6. I think I found the sensor right above the starter and below the oil filter but it looks impossible to remove if that is it.
anyone knows of any DIY for this sensor on this motor?
thanks
Good luck.
thanks for all the help!
