E430 Headlights upgrade!
Old Jun 1, 2010 | 02:40 PM
jluu1286's Avatar
2001 E430
Hey everyone!
My E430's headlights has not been touched since day one (sadly) and it is getting extremely dull. I tried to polish it for about 3 hours but, I think it has been too long. So I started searching around and I found something similar to the w211 headlights. I wanted to know where can I buy these (except for ebay).
Here are some pictures of what I want to change my lights too... Please take note this is not my car but similar.
This is what I have:
And this is what i want to change them to.
Thanks in advance!
Old Jun 1, 2010 | 02:56 PM
saintz's Avatar
GL450
They're made by Depo.
Old Jun 1, 2010 | 03:00 PM
jluu1286's Avatar
2001 E430
I see...Do you recommend them or you think I should get some amazing cleaning products to clean my headlights?
Old Jun 1, 2010 | 03:35 PM
Air Marshall Eldritch's Avatar
John Deere
Have you tried the 3M cleaning kit? Usually on Ebay for $20 or so.
Old Jun 1, 2010 | 08:18 PM
BigBoss's Avatar
2002 Mercedes Benz E320
I picked up the 3M cleaning kit from my local Autozone for less than $20. Worked great but I missed some spots on the outer most edges of the headlights but nothing noticeable unless you get really close to it.
Old Jun 1, 2010 | 08:51 PM
jluu1286's Avatar
2001 E430
How long did it take you...I bought some product from Autozone with little results.
Old Jun 1, 2010 | 09:01 PM
raymond g-'s Avatar
99 E320
jluu -
the actual headlights you're reference underwent the following transformation.
though subtle (from the photo), in actuality, it was correctly identified by saintz
as a Depo, but with much more work added. it sports the OEM bixenon from an
E55 inside, so the cutoff and beam projected is of much higher quality than
that of the unaltered Depo/Taiwan headlight....which is quite miserable, otherwise
Old Jun 1, 2010 | 09:15 PM
BigBoss's Avatar
Probably about an hour, maybe a little more because I taped off the area surrounding the headlights with newspaper so the car didn't get dirty.
Old Jun 1, 2010 | 09:30 PM
jluu1286's Avatar
2001 E430
Would you mind taking a picture by any chance I just want to see how good it looks before I spend the time to do it.
Old Jun 1, 2010 | 09:59 PM
BigBoss's Avatar
There you go.
Attached Thumbnails E430 Headlights upgrade!-100_3644.jpg   E430 Headlights upgrade!-100_3645.jpg   E430 Headlights upgrade!-100_3646.jpg   E430 Headlights upgrade!-100_3647.jpg
Old Jun 1, 2010 | 11:30 PM
jluu1286's Avatar
2001 E430
There you go.
Ty so much looks to me like I will be doing this!!!
Old Jun 1, 2010 | 11:34 PM
jluu1286's Avatar
2001 E430
Originally Posted by raymond g-
jluu -
Sounds to me like I need to just get a chair sit down and start cleaning those headlights!
Old Jun 2, 2010 | 06:55 AM
saintz's Avatar
GL450
I use a Mr Clean Magic Eraser, rubbing compound, and Meguiars PlastX on mine. It takes all the yellow and haze out. I would try that first.
Old Jun 2, 2010 | 10:10 AM
jluu1286's Avatar
2001 E430
Did you have to use and sand paper, buffer machines, or any types of rubbing tools or was it just your hand and Mr. Clean?
Old Jun 2, 2010 | 11:14 AM
saintz's Avatar
GL450
By hand. If you use any type of buffer or drill attachment, you need to be careful of your paint. The Mr. Clean won't take out large pits the way a grinding tool would, but it will scrub the surface pretty thoroughly.
Old Jun 2, 2010 | 11:22 AM
jluu1286's Avatar
2001 E430
How long did it take you and does it look like you just bought the car off the lot :p?
Old Jun 2, 2010 | 05:04 PM
monsterman75's Avatar
2001 E320 4matic
Sometimes forums are bad. As in "Hey dear I think we need to replace the headlights and I know just the product"
"Any chance there is a cleaning product?"
"Um, well none that would really make all the difference, and we could get better lights..."
"Let's see what the forum has to say..."
"See I told you there was a cheaper way to make the lights look new...."
Old Jun 2, 2010 | 09:28 PM
saintz's Avatar
GL450
It worked well on mine. Few chips, but looks good. Another one I tried it on didn't get it totally new. The problem is if you get too aggressive, you cut into the plastic and soften it, so it will get worse over time.
