97 E420 Installed NGK Platinums, Is There A Problem ??
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
97 E420, 140K Random Multiple Misfire / Cyl 5,6,7 Misfire, Replaced 2 coils
Replaced Plugs(NGK Platinum) Problem still there, Replaced Mass Air(Salvage Yard) Idles better still has misfires ??
Thanks In Advance
BJW
Thanks In Advance
BJW
The E420 210 not comes with spark plug wires.. they have8 coils insert direct to the spark.. i'm pretty sure you have a bad head cover gasket & you get oil inside the spark site. try to check. if you have oil cange the gasket clean all the oil with some "thiner" & clean too the rubber part of the coils (maybe you need to replace the "8" rubber conductor by the coils) is pretty common this fails in te M119 updated engines
Other way, try cleaning the fuel injectors too (common issue in the m119)
Fabio Daniel
Fabio Daniel
![Post](https://mbworld.org/forums/images/icons/icon1.gif)
Hey anesh01,Fabio D,
Thanks for the reply, Yeah I have 8 coils, There is no oil down in the wells,
I checked for that first, Driver Info center Says Check Engine Electronics, Guess I'll look into the injectors
You never use
platinum plugs on the 420 or the M104 copper plugs is what they likes.
Also you replace the connectors when you do the plugs.
Beru (OES)
Spark Plug Connector; Between Coil and Spark Plug
For models with distributorless ignition, having individual coils for each cylinder. 1 per cylinder.
$14 at autohausaz.com common issue on the m119
Beru (OES)
Beru (OES)
Beru (OES)
Try cleaning it first. hope you solve the missfire
Fabio Daniel
