City Lights
Old Jul 20, 2010 | 11:46 PM
raptor3k's Avatar
2001 E320 4matic
City Lights
What size are the city bulbs, I see H6w here and when i called advanced auto parts and checked sylvania.com they said H7?
Old Jul 20, 2010 | 11:49 PM
bmroxm5's Avatar
W210 E320
H6W is correct.
H7 is for low beam (outer housing) lights and a seperate H7 bulb in the inner headlight housing for high beam.
EDIT: Sylvania calls it a 'parking light'. As do we in Australia
Old Jul 21, 2010 | 08:10 AM
saintz's Avatar
GL450
You'll have a hard time finding the right bulbs at an auto parts store. The bulb is an H6W, which you might be able to find, but the base is a BAX9S which has the two pins at an angle. Most bulbs you'll find in an auto parts store will have a base with the pins at exactly 180 degrees. You'll need to either get the proper bulb (dealer or search online like on eBay for BAX9S) or if you buy from a local store, take pliers and remove one of the pins.
Old Jul 21, 2010 | 08:48 AM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
There are a few alternatives
When the time came that I needed one I got two from the dealer. It was shortly afterwards that this thread started - almost a year ago:
http://www.benzworld.org/forums/w210...w-philips.html
Hope it helps.
Cheers
Old Jul 21, 2010 | 09:48 AM
michakaveli's Avatar
E300
Anyone figure out a replacement for the bulb holder. After some time they become fragile and break apart.
Old Jul 21, 2010 | 07:35 PM
01BlackE320's Avatar
01 E320
Instead of the H6 I used Sylvania 3893 (T4W) bulb which is readily available at Pep Boys. Bulb looks identical and works just fine. Slightly dimmer then the original bulb (4 watt vs 6 watt) but you'll barely notice it. If you replace both you definately wont notice it. The package is labeled License, Parking and Side Marker - European Lamps and its about $3 for two bulbs.
Old Jul 21, 2010 | 11:18 PM
NihalS65's Avatar
1992 500SEL Black and grey 2 tone w/ camel brown interior
Saintz- Genius. i just had the same problem to. no parts store has the exact same bulb because of the staggered pins. but im definetly goin to try removing one of the pins on the store bought ones.
Old Jul 29, 2010 | 08:26 PM
BigBoss's Avatar
2002 Mercedes Benz E320
Any idea where to get LED parking lamps to match the Xenons in color? I've seen some on ebay but all are the "warm white" which is kinda yellow.
Old Jul 30, 2010 | 09:38 AM
saintz's Avatar
GL450
The LEDs you see on eBay will actually be slightly bluer than the stock Xenon lights, despite what color they may look in the ads. Most will throw a bulb out error code, unless you either wire in a resistor or get one of the "no error" bulbs.
Old Jul 30, 2010 | 03:50 PM
mike430sport's Avatar
2000 E430 Sport
I changed mine to a wedge base. I bought leds and resistors
Old Jul 30, 2010 | 05:01 PM
lkchris's Avatar
'10 CL550, '12 GL550
These are correct color but not LED which is neither here nor there and for sure nothing special.
http://www.powerbulbs.com/product_li...at1=39&cat2=29
Old Jul 30, 2010 | 06:56 PM
BigBoss's Avatar
Where did you get it?
Old Jul 31, 2010 | 02:49 PM
Javys21's Avatar
01 E320
Ebay
Type parking light w210 e320.. I got japanese bulbs 6w. which are brighter blueish tint to it.
