SPARK PLUG TIME
Old Jul 27, 2010 | 10:57 PM
Javys21's Avatar
01 E320
SPARK PLUG TIME
Can anybody help me out with a DIY and part numbers.
Old Jul 28, 2010 | 09:32 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
There are DIY's for plugs at both peachparts and benzworld.
The Bosch site lists appropriate plugs since the ones listed in the OM have probably been replaced. Some claim to use single electrode plugs (either Bosch or NGK). I've had no problems with the dual electrode platinum Bosch. YMMV
Special 17mm Hazet valve adj wrench (110.589.01.01) makes pulling the boots off and on very easy. Otherwise wires can get damaged. Note: "A" plug wire to front plug and "B" to back. It's marked on coils. No anti-seize compound as modern plugs have special coating.
Torque: Plugs are 28Nm (5/8" or 16mm) and coil mounting bolts (T30) are 8Nm. Tight quarters so it's slow going but it's only once every 100K.
Old Jul 28, 2010 | 11:20 PM
ohlord's Avatar
or 5
years which ever comes first
So most people are way overdue.
bosch 7422
ngk 7090
Old Jul 28, 2010 | 11:23 PM
Sathinas's Avatar
S65
Or 15K miles or one year, whichever comes first in my case... :/
You lucky bastages! You only have to change them every 5 years!
