Stock brakes or Autohausaz.com brakes
OEM pads and rotors are available from autohausaz so your braking performance should be the same assuming a competent mechanic does the work.
You can also get DOT4+ fluid, wear sensors, MB brake paste and new rotor mounting bolts (optional). If it's been 2 years, flush the brake fluid as part of the job.
Also, MB recommends replacing the caliper mounting bolts which are micro-encapsulated. (Note: Not the guide pins which the pads ride on.) You will probably need to get those from a dealer.
