LAMP OUT WARNING
Old Sep 16, 2010 | 04:53 PM
BLUEBENZ230's Avatar
LAMP OUT WARNING
I'm tired of seeing this every time I start the car.All ights are working other
than having aftermarket HID kit and smoke tail lights. Is there a way to get this thing off? Thanks.
Old Sep 17, 2010 | 07:21 AM
bmroxm5's Avatar
W210 E320
do you know what's causing the error message? ie it didn't appear before the HID kit.. now it appears? try a 'canbus' decoder http://store.ijdmtoy.com/Canbus-Deco...us_decoder.htm
Old Sep 17, 2010 | 05:00 PM
Thank you. I just ordered it. I also have the tail lights.
Old Sep 17, 2010 | 07:38 PM
MG's Avatar
MG
Veteran: Army
1998 E430; 2007 Porsche 911 C4S Cabriolet; 2011 Expedition EL Limited; 2014 E350 Estate
Mine just started this a couple months ago, and I changed head and tails out a couple years ago, so I am sure its not an LED resistor issue. Typically false defective lamp warnings are an indicator of low voltage in the battery. I had the same issue five or six years ago before I changed my battery. Never had a false warning again until now. I am thinking I need to swap out the battery again before the cold sets in.
Old Sep 23, 2010 | 11:11 AM
Not working
I received the decoder last night and I put it on. I still get lamp defective warning every time I turn the light off only when the engine is running. It does not do it after I turn the engine off first. Dont know what to do. Is there a solution for this?
Old Sep 23, 2010 | 11:25 AM
monsterman75's Avatar
2001 E320 4matic
MG, that is very interesting. You know I wonder if my battery is on its way out.....
Old Sep 24, 2010 | 03:39 AM
sandro's Avatar
96' E320
Maybe your side marker light is out? Or a license plate light. something small you just havent noticed yet.
Old Sep 24, 2010 | 01:31 PM
Check all lights. All of them are working fine. How come it only happen when I turn off the headlight when the engine is running. not the park light. it doesnt do it. Also, it does not do it after I turn the engine off.
Old Sep 24, 2010 | 02:22 PM
raymond g-'s Avatar
99 E320
i happen to believe (and have seen) light malfunction alert activated after
the owner installed HID kit...as well as LED tails. So i'm in the camp that
believes these modifications can cause warning light to come on.
when the new light mod was removed and OEM restored, the warning light
extinguished. new mod put on, warning light back on.
Old Sep 24, 2010 | 02:50 PM
ohlord's Avatar
Also your
shut off procedure that works has been discovered by many members that have installed these cheap kits.
The ones that don't want to remember what sequence to turn off the lights and car just resort to hitting the button that clears the malfunction warning and live with it.
Old Sep 24, 2010 | 03:28 PM
raymond g-'s Avatar
99 E320
had you not identified the mods (front/rear) i would have questioned whether
you actually checked all exterior bulbs. folks (sans mods) frequently miss
a bulb. the whole list of monitored bulbs has been posted many times. but
from memory while sitting in the office, I recall....
low beam (2 bulbs)
high beam (2)
front turn (2)
front city light (2) below high beam
clearance (2) front bumper, side
high brake light, aka Dole (2) above trunk
reverse (2)
tail lights (2) two, dual filament bulbs
rear license (2)
Old Sep 24, 2010 | 09:45 PM
MG's Avatar
MG
Veteran: Army
Fudge. Now I am going to obsess about my reverse lights. I never checked them.
